  1. Banned
    May 2006
    Downloaded a couple of movies in .IMG format, once I unpacked it with Winrar.
    Tried to burn them with Alcohol 120 % and one of them was a success, I was able to view in on a Stanalone DVD player.
    The Other one , is totally mess up, with the picture, fluantuating Up and Down....
    About to do the Thrid one or try it with Alcohol again ,but I have a lot of reservation and doubt......
    any advice?
  2. Banned
    Freedonia
    Alcohol 120% should be OK, but you can try the free ImgBurn if you like. It's what many of us use.
    Burn to DVD+/-RW so you at least don't waste discs.
    Consider installing the free Daemon Tools program and mount your ISOs with it and play them prior to burning to check that they are OK.
    Your pulsating picture sounds like a typical PAL-NTSC mismatch problem. That DVD is probably PAL and your TV can't handle it. Check your DVD player and see if you can set the video output to NTSC. Many DVD players have the video output set to MULTI or ANY and this is wrong for a lot of American TVs. It needs to be NTSC.
    USA
    You should also be able to play back most ISO files with VLC Media player without having to use Daemon Tools.
  4. Banned
    Freedonia
    I was not aware of this, hence the suggestion to install Daemon Tools. That's good to know.
  5. Originally Posted by redwudz
    Yep, great feature. I hardly ever use Daemon tools anymore.
    It does the menu and everything...Not sure if it will open a img file though. Only time i deal with img files is with WinImage, and that's usually uncompressed floppy images
    Originally Posted by jagabo
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Is it playing in B&W also ??
    Sounds like a PAL issue.
    Although i'm not sure what fluantuating is
    Edit:
    Reading again i see jman98 already mentioned it 8)
  7. Banned
    May 2006
    Thanks guys,,,,,,,
    First off, I do NOT have problem on how to View the Extracted .Img file, I know how to use and I am aware of Daemon, VLC players
    Just concern about the Fluatuating, Never thought whether my "Old" DVD does have an option on PAL /NTSC...
    Update:
    Setting the DVD Player to PAL60 , did the JOB
    >>>>> U guys are a GENIOUS.....Save my Life !!, Thanks Thanks !! Thanks....
    Hope this will help some other ppl with this minor problem.Cheers
