Hi...i have a 52" JVC HD-52z525 that can accomodate up to 1080i...i just bought a Samsung BD-P1500 & have them both hooked up via HDMI...they dont seem to want to communicate...nothing...no picture...nada...but i did connect them vai a A/V cable & just got a poor dvd quality picture...ive tried every configuration in each of the set up pages to no avail...is it just a matter of pressing the correct buttons in the correct order or should i just return the BR player?? thanks for the input...
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
It should work. The TV only has 720p resolution, but that isn't the problem. It also likely isn't a bad player, but you can try swapping it and the cable for that matter. This being an older TV with early HDMI, there may be an HDCP issue between the player and TV.
Google is your Friend
VOB2MPG Pro Blu Ray Compatible
By natejeng in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 13th Feb 2011, 12:59 -
x264 compatible with Blu Ray Player
By klode in forum EditingReplies: 6Last Post: 22nd Aug 2010, 15:23 -
Blu-ray to Apple TV compatible format
By sangood in forum Blu-ray RippingReplies: 5Last Post: 19th Jan 2010, 23:18 -
Blu-ray compatible h264?
By Bergen in forum Video ConversionReplies: 4Last Post: 6th Aug 2009, 08:59 -
1TB Blu-Ray-compatible disc!
By akrako1 in forum Latest Video NewsReplies: 22Last Post: 4th Jun 2008, 00:56
