I want to add an additional monitor to my computer. I am intrigued by the idea of using a usb video card because it will not add more heat to the inside of the computer. I want to use the second monitor for video editing when doing real time editing - use the first monitor to view the video and the second monitor to make the changes - but will also use the second monitor in other situations mainly for IM chatting and surfing to support the work that I am doing on the main monitor.
Do you think this is a good idea? If so, what things should I look for in a usb video card?
Keep the heavy lifting video on the internal card and then test the USB card for simple display and find it's limits. I've wanted to test one of those. They usually lack video acceleration features typical of better internal cards (e.g. PureVideo, Avivo or game 3D).Originally Posted by xinjingqiaoRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 02:02 -
How to connect internal USB 2.0 card reader in older PC?
By bevills1 in forum ComputerReplies: 24Last Post: 15th Apr 2009, 08:05 -
internal pci and a usb adapter
By vipertongn in forum ComputerReplies: 6Last Post: 27th Jul 2008, 17:06 -
dvd recorder or usb tv / video card
By faithzzzz in forum DVD & Blu-ray RecordersReplies: 5Last Post: 13th Sep 2007, 11:09 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 12:58
