  1. Member thecrock's Avatar
    May 2005
    england
    Can any member point me in the right direction for virtualdub filters, I had a filter which 'cartoonized' a movie but new computer and I didn't backup my plugins.
    Peace
    “He who makes a beast of himself gets rid of the pain of being a man.”
  2. Member Soopafresh's Avatar
    Jan 2004
    Probably the MSU Cartoonizer
    http://compression.ru/video/cartoonizer/index_en.html
    Here's a good list of some of the more popular Vdub filters as well
    http://www.thedeemon.com/VirtualDubFilters/
  3. Member thecrock's Avatar
    May 2005
    england
    I would like to add the greysale filter but when I save it I get a huge file. How can I compress none of the video codecs seem to work. Error message stats file not found and the error code -1.
    Anybody?
  4. Mod Neophyte redwudz's Avatar
    USA
    You have two problems. The 'stats' file error happens when you try to do a two pass encode and select the second pass first in error. Do the first pass and that will generate the 'stats' file. Then the second or additional passes will use that file for the next passes.
    The huge file problem is usually because you didn't select a codec. VD will default to a RGB codec and the file will be 'huge'. Just select the desired codec next time.
    When you add a new codec, you have to restart VD and it should show up in 'Compression'.
  5. Member thecrock's Avatar
    May 2005
    england
    I have virtualdub and virtualdubmpeg2 where are the filters in virtualdub? as I can't find them.
    I just downloaded the latest release and everthing seems to be fine.
    Thanks for the help guys.
    Peace
  6. Mod Neophyte redwudz's Avatar
    USA
    They are installed to the 'Plugins' folder inside the VD program folder. You will only see the filters you added. The others are part of the program. You only need the part with the .vdf extension. Restart VD and they should be available in your filter selection.
  7. Member thecrock's Avatar
    May 2005
    england
    Thanks for the help REDWUDZ and SOOPAFRESH.
    Peace
