I've copied some of my Ally McBeal disks, but I just realised it's only copying the first episode of each disk.
Try instead the free and UPDATED DVDFab Decrypter and then use DVD SHrink if you want to shrink it.
I just tried it. That didn't work either. The preview works though!
thanks -
I just realised it worked properly on windows media player! I also realised I used DVD+R for these copies, but, we usually use DVD-RW to tape and watch shows afterwards, even though it says it uses both types. I'll try it on the DVD-RW and see how that goes.
Another question, these +R discs also say RW further down, does this mean they're rewritable as well? They won't allow me to rewrite them, but I assume it must have automatically been finalised.
thanks for your help
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
DVDFab Platinum missing 99.9% of DVD, but 100% of it shows in DVD Shrink!??
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 12Last Post: 22nd Oct 2009, 18:31 -
Shrink Xvids to fit episodes on DVD
By Wolfbrain in forum Video ConversionReplies: 5Last Post: 20th Apr 2009, 11:40 -
Subtitles missing after using DVD Shrink.
By siuol in forum Authoring (DVD)Replies: 5Last Post: 30th Jun 2008, 21:40 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59
