  1. I'm working on converting a DVD to H264, but the encoding process never gets past the audio stage. I'm converting the original 5.1 AC3 audio to AAC 2-channel with Nero AAC. The encoder, Nero AAC, loads up fine and even, seemingly, encodes the audio. After it encodes, the status changes to "Finalizing Encoding" for a while, and then the Nero AAC window disappears, leaving an error message for the Audio encoding. The error message that it leaves is this: "Attempted to read or write protected memory. This is often an indication that other memory is corrupt."
    Please, any help would be greatly appreciated, as this is really getting on my nerves.
  2. Delete the post.
  3. well u r having error because ur offline megui doesnt have the right path to the encoder...
    open MeGUI...
    click on the options tab.....
    select settings....
    in settings tab select external programme settings
    in the nero aac enc ......manually browse the location of the offline installer megui folder which has nero encoder.....
    and save it...
    voila....problem solved.....
  4. well i presume that u have copied the nero encoder files to ur megui folder...
  5. Delete the post.
