H:\>cd Dick Tracy (1990)
H:\Dick Tracy (1990)>divx264 -br 700 -npass 1 -i MyScript.avs -o 1stpass.h264
Framerate outside profile specification (23.976Hz) (2997/125)
Does that look like it's encoding? I get a flashing white cursor.
Originally Posted by jagabo
Results 31 to 47 of 47
http://labs.divx.com/node/6992
Try adding "-fps 24000/1001" to the command line.
Instead of encoding a whole movie I suggest you work with a 1 minute clip until you've figured out what you're doing. -
I got it. Does H.264 require MP3, or AC3, for audio? I am just curious.Originally Posted by jagabo
What do you mean audio is a container issue? I am encoding my video with MP3. That isn't good?Originally Posted by jagabo
h.264 is a video codec. It has nothing to do with audio. What audio codec you want to use will depend on what container you will be putting your audio and video in and what capabilities your playback device has. The Divx docs use MkvMerge. Since you are only concerned about playback on your PC MP3 audio is fine in an MKV container.
It has to be for my PC unless I have a HD DVD player. I don't have one so I can't play it on my TV. I might email him and ask him do they plan on making DivX 7 for Philips, or regular standalone. I know they are making them for playback. I am not sure for playback of just HD DVD, or what.Originally Posted by jagabo
MP4 is a more common container and AAC-LC audio at 128kbps - 256kbps (in that range) is the standard.
So for the future I suggest you use AAC-LC and the MP4 file container.
XVID4PSP is a nice program for both H.264 video encoding and AAC-LC audio encoding.
- John "FulciLives" Coleman
P.S.
When I say MP4 is more common I mean for H.264 video use."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I don't know how successful Divx (the company) will be in convincing the big consumer electronics manufacturers to support MKV.
jagabo,Originally Posted by jagabo
One of my movies worked with encoding, and everything. The second won't encode. I tried to encode it both ways. The first way worked fine the first time after I tried it. The way with -fps also worked but now it doesn't. Should I post a new thread? I will post my CLI logs. Am I doing it right? I think I am.
C:\Program Files\DivX\DivX H.264 Codec CLI\bin>H:
H:\>cd E.T. The Extra-Terrestrial (1982)
H:\E.T. The Extra-Terrestrial (1982)>divx264 -br 800 -aqo 2 -npass 1 -i MyScript
.avs -o 1stpass.264
Error: Width or height outside profile specification (640x56)
H:\E.T. The Extra-Terrestrial (1982)>divx264 -br 800 -fps 24000/1001 -aqo 2 -npa
ss 1 -i MyScript.avs -o 1stpass.264
H:\E.T. The Extra-Terrestrial (1982)> -
DivX 7 places constraints on these properties, requiring that the picture dimensions be at least 320x240 pixels with width and height each being multiples of eight -
The Width and height is 688x384Originally Posted by jagabo
Do I need to resize it? It's 16:9 at 23.976 which is NTSC. I was thinking resize to 640x352? -
According to MediaInfo it's 688x384. I will post the video file with no audio. Here are the logs.Originally Posted by jagabo
General
Complete name : H:\E.T. The Extra-Terrestrial (1982)\video.avi
Format : AVI
File size : 1 018 MiB
Duration : 2h 0mn
Overall bit rate : 1 186 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 2h 0mn
Bit rate : 1 181 Kbps
Width : 688 pixels
Height : 384 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.186
Stream size : 1 014 MiB (100%)
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01) -
Not after you did whatever you did in the AVS script.Originally Posted by rocky12
My script is fine. I have AVISource. I did had ChangeFPS and I took it out of my script. I get the same error so it's not my script.Originally Posted by jagabo
AVISource("H:\E.T. The Extra Terrestrial (1982)\video.avi")
That is my script now. With or without ChangeFPS, I still get width and height errors. -
I am sorry, jagabo! I was making the same mistake all day long that I never made in months. That is why we have VirtualDub, or even VirtualDubMod to see if our scripts are right to load. I have been like this all day. It is now 14:40 EST. I translate. 2:40pm. I have it encoding now.Originally Posted by jagabo
VHS to DVD Restoration. Best AviSynth scripts?
By VideoFanatic in forum RestorationReplies: 47Last Post: 25th Oct 2011, 07:34 -
About using AviSynth scripts with MeGUI 0.3.5.0.
By Nagashi in forum DVD RippingReplies: 56Last Post: 15th Jul 2010, 11:15 -
StaxRip doesn't handle 16:9 AVISynth scripts?
By Kylenol in forum Video ConversionReplies: 0Last Post: 23rd Dec 2009, 16:35 -
H.264 deinterlacing AVISynth scripts for 29.97fps
By PuzZLeR in forum Video ConversionReplies: 12Last Post: 7th May 2008, 23:36 -
Avisynth scripts and VDubMOD filters
By GangstaRap in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 12:39
