Trouble concatenating mp4 files in Yamb 2.0.0.8
The files seem to combine fine.
But, in playback on VLC- 2 videos open and play at once. (1 is normal; the other is named "hardware YUV directX output")
-- in Quicktime-
Only 1 video plays back, with the audio from Vid 2
- i did everything properly (as far as i can tell), and downloaded Mp4 box along w/ Yamb.
Results 1 to 9 of 9
Try YAMB 2.1.0.0 beta 1 released very recently:
http://kurtnoise.free.fr/index.php?dir=Yamb/
You might also try avidemux
What formats are contained within the .mp4? use mediainfo if you don't know. Sometimes extra "stuff" like subs etc... can impair the joining. -
Nothing "extra" in videos - strange, I couldn't join ANYthing properly with Yamb 2.0.0.8 or the beta 2.1.00
- avidemux works, but the resulting mp4 is HUGE (guess i can compress it).
Also -- on Playback, at each spot with the mp4s are joined, there's a Loud puff of audio static.
Anyway to get rid of that?
(Thanks for your help, by the way.) -
In avidemux did you use the correct settings (video & audio set to copy, format set to .mp4) and the latest SVN?
http://avidemux.razorbyte.com.au/
You could try muxing it into .mkv container, and join it (with mkvmergeGUI), export the streams and then use YAMB to switch containers
Again, what formats are contained within the .mp4? (e.g. AVC video, AAC audio, etc...)?
You might have a problem with your .mp4 "ends" where there is a gap or audio offset -
YES! This did it for me! Here's my process to get my merged mp4s from streaming websites (youtube, etc) now:
Download media with Replay Media Catcher (likely flv format)
Extract to h.264/aac with FLVExtract
Mux/combine streams to mp4 with Yamb
(these steps were always simple enough, but your tips helped add the next few steps!)
Merge/mux all desired mp4s together with MKVToolNix
Re-extract stream to h.264/aac with MKVExtract GUI2
Re-mux/combine streams to mp4 with Yamb
I now have one merged mp4 with seamless audio and video, and all without re-encoding a single frame throughout the entire process! Thanks a bunch!
MkvToMp4 vs YAMB
By jandor2009 in forum Video ConversionReplies: 0Last Post: 4th Jan 2012, 05:52 -
Can MP4Box does everything YAMB could?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2011, 11:07 -
Can Someone recommend an Alternative to YAMB
By Scarpad in forum Blu-ray RippingReplies: 4Last Post: 5th May 2010, 14:39 -
Yamb Source Code
By simonrule in forum ProgrammingReplies: 0Last Post: 3rd Nov 2009, 11:50 -
BitStream Not Compliant with YAMB
By bidomo in forum DVD RippingReplies: 2Last Post: 9th Jul 2007, 23:56
