Hi all,
Until now I converted all my MiniDV to Mpeg2 format and burned as DVD.
Is there any reson to convert the MiniDV to H264 ? I heard it's half the Bitrate of Mpeg2 and same quality.
Depends on what you want to play it back on. If you want to use a set top DVD player, either MPEG-2, or if you have a Divx player, Xvid or Divx formats would be another choice.
H.264 will give you smaller file sizes, but takes more computer power to encode and to decode for playback. And most times you would need a computer for playback.
You could make up a short representative clip and try some different codecs and codec settings to see what quality you would end up with.
And welcome to our forums. -
H264 is the future. Mpeg 2 is the bigger part of the present.
Mpeg 2 on a superbit DVD with the highest possible bitrate (9800kb/s) wasn't always enough to keep the 100% of the DV picture quality. And that shows mostly on big LCD TV Screens (42"+ ).
H264 on around 6.000kb/s is capable to hold the 100% of DVs picture quality. Probably even 4.500 is enough.
Of course, at the time being, there is also the question of where you gonna playback those H264 files. Older PCs have problems with them and only BD players (and HD DVD ones) and some mediaplayers are capable to playback them.
Personally, I would encode those files twice: on mpeg 2 to watch them on any DVD player and H264 to store the for the future. -
Originally Posted by SatStorm
If the goal was merely to save space (not save quality), I'm not sure I'd bother with the H264. But then again, most of my video is not great quality anyway... -
Originally Posted by tmw
I log the DV/HDV tape and only save the good stuff. For camcorder that usually means 25-35% of raw video hits the cutting room floor. When I use DV for TV captures I just save the MPeg2 unless the material is somehow special.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
@tmw: On HD DVD, it was possible to author regular DVD-Rs with H264 material as HD DVD discs, and playback them on those standalones.
Later BD have this option too, but I never used it. I don't even know how to make those kind of discs. -
Originally Posted by SatStormI think,therefore i am a hamster.
H264 to MPEG2, best way ?
By boulder in forum DVB / IPTVReplies: 9Last Post: 30th Aug 2009, 17:49 -
Subtitle control lost after cutting and format convertion to .wmv
By Knut Skog in forum SubtitleReplies: 1Last Post: 25th Jun 2009, 13:51 -
DVD to MPEG2 convertion
By Divider in forum Newbie / General discussionsReplies: 5Last Post: 8th Mar 2009, 04:12 -
Advice for batch mpeg2-xvid convertion please
By felix in forum Video ConversionReplies: 3Last Post: 5th Feb 2009, 05:53 -
How to automate convertion from HD signal to HD-Divx or other format
By fta123 in forum DVB / IPTVReplies: 7Last Post: 18th Jan 2008, 11:55
