I have a Time PC with windows XP Home edition, service pack 2.
When I bought it a few years ago, it definately had usb 2.0, but now when I connect my digital camera, no matter which port I plug it into, up pops a box telling me to plug it in to a highspeed port. But none of them seem to be any more.
it tells me to click to see a list of high speed ports, when I do so it lists "VIA USB 2.0 enhanced host controller" with a + dropdown to writing in bold saying "USB root hub (6 ports)" and six icons below, with "unused port" beside them"
Someone told me that the service pack updates caused this problem.
is there any way to solve this?
Thanks.
You may have this problem or this.
You can also check if your motherboard has newer usb or other chipset drivers. -
Go back to device manager and uninstall each device under universal serial bus controllers, finally followed by the main "universal serial bus controllers"
Reboot the system and it will automatically detect and install the device drivers, reboot again after
Always handy to have the latest drivers for motherboard ... some of those via powered motherboards actually came with usb2 drivers
The "unused port" is questionable and should not exist ... they just exist or declare error state
Quite possible its another "corrupted driver" syndrome which happens ... but worth checking you bios setup and motherboards battery
VirtualBox & USB problem
By kenmo in forum ComputerReplies: 12Last Post: 3rd Nov 2009, 18:45 -
USB Capture Problem
By sdculp in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2009, 15:52 -
Problem with my USB ports...
By nhbfan12345 in forum ComputerReplies: 3Last Post: 6th Oct 2008, 18:15 -
Vm Ware+Xp+USb:problem
By themaster1 in forum ComputerReplies: 3Last Post: 4th Jul 2008, 18:28 -
Problem with Hauppauge USB 2 Tv Tuner
By JustinR123 in forum Capturing and VCRReplies: 4Last Post: 29th Jun 2007, 03:01
