I am currently using DVDFab, DVD Rebuilder, and ImgBurn
for ripping and backing my DVDs.
I am happy with DVDFab 5 and ImgBurn but DVD Rebuilder is
very slow.
DVD Rebuilder is very good but exceeding slow taking hours
to recode to get from DVD9 to DVD5. Can anyone recommend
another FREE tool that take less time (with decent video
quality)? Thanks
You may want to upgrade that celeron to a dual, triple or quad-core processor to get better speed. DVD-RB is one of the best, but getting the quality that it does takes time (especially on your system). I use HenC with DVD-RB on an Athlon x2 5000, and it recodes in real-time or less.
If you're by a Fry's, you can often get the mobo & cpu for under $80 (slightly more for a better, non-ECS board). -
How to convert Blu-ray to standard DVD-Video (or MKV,MP4) using free tools
By Baldrick in forum User guidesReplies: 4Last Post: 22nd Oct 2015, 21:39 -
How to convert a Blu-ray to a standard DVD using free tools
By Baldrick in forum User guidesReplies: 5Last Post: 11th Aug 2013, 22:50 -
How To Create A functional button and replace the DVD menu using free tools
By escarlate in forum User guidesReplies: 4Last Post: 31st May 2011, 02:44 -
How to merge/convert Meg2 video and burn to DVD using free tools
By bahjan in forum User guidesReplies: 0Last Post: 22nd Aug 2010, 12:42 -
Any free tools to author DVD structure with menu buttons?
By p23185 in forum Authoring (DVD)Replies: 1Last Post: 1st Mar 2010, 17:03
