  1. Hi,
    I've shooted holidays videos. These videos were shooted with 2 différent cameras (a mini dv one and a mini dvd).
    There is just a small problem, the sound level is not the same for both cameras.
    So, how can I make the volume more constant between all scenes (videos are mixed togheter like this DV-DVD-DV-DV-DVD-DV,...)
    If is better to use the normalize function on each individual wave file ?
    Use RMS volume normalize ?
    Other method ???
    I use Soundforge 9 to edit my audio files.
    Thanks.
  2. No ideas ???
  3. Member Soopafresh's Avatar
    Jan 2004
    Peak volume normalization or normalize to -1dB, then apply dynamic range compression (should be an audio plugin for that, maybe wavehammer? I don't use Soundforge) to even out the levels more.
