I've seen numerous examples on the web on using profiles in your config files, and i've read it in mplayer's docs, but i never found ANY ONE stating the name of the file to place it in. I noticed that the ~/.mplayer/config file said something about adding custom options there, but when i did, i got several errors. I will paste the config (well, a snippet of it), and the resulting errors:
Code:[x264-1.6] profile-desc="Standard Widescreen Settings, from Standard DVD (NOT Blu Ray or HD)" vf=pullup,softskip,harddup,dsize=1.6 ofps=25 aspect=1.6 force-avi-aspect=1.6 ffourcc=h264 passlogfile=log.log oac=faac faacopts=br=128 ovc=x264 x264encopts=partitions=all:8x8dct:weight_b
Does anyone know what could be causing this?Code:[^v^] mplayer video.avi -profile help; MPlayer dev-SVN-r27514-4.3.2 (C) 2000-2008 MPlayer Team CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4800+ (Family: 15, Model: 107, Stepping: 2) CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 1 Compiled with runtime CPU detection. Warning unknown option ofps at line 4 Warning unknown option force-avi-aspect at line 6 Warning unknown option ffourcc at line 7 Warning unknown option passlogfile at line 8 Warning unknown option oac at line 9 Warning unknown option faacopts at line 10 Warning unknown option ovc at line 11 Warning unknown option x264encopts at line 12 Warning unknown option x264encopts at line 20 Warning unknown option x264encopts at line 25 Warning unknown option x264encopts at line 34 Warning unknown option x264encopts at line 39 Warning unknown option x264encopts at line 48 Warning unknown option x264encopts at line 53 Warning unknown option x264encopts at line 62 Warning unknown option x264encopts at line 67 Warning unknown option x264encopts at line 76 Warning unknown option x264encopts at line 81 Warning unknown option x264encopts at line 90 Warning unknown option x264encopts at line 95 Warning unknown option x264encopts at line 104 Warning unknown option x264encopts at line 109 Warning unknown option x264encopts at line 118 Warning unknown option x264encopts at line 123 Warning unknown option x264encopts at line 132 Warning unknown option x264encopts at line 137 Available profiles: ...
Thanx
===EDIT===
Part of the problem is because i said "mPLAYER" and not "mENCODER". But now that i've corrected that, i get a new error:
Suddenly, there are no profiles? Does it read from a separate file for mencoder, as opposed to mplayer?Code:[^v^] mencoder video.avi -profile help; MEncoder dev-SVN-r27514-4.3.2 (C) 2000-2008 MPlayer Team CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4800+ (Family: 15, Model: 107, Stepping: 2) CPUflags: Type: 15 MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 1 Compiled with runtime CPU detection. No profiles have been defined.
==EDIT==
Nevermind. I finally got it: "mencoder.conf" is the required file name. That was the problem.
Someone should probably just delete this thread...
Results 1 to 1 of 1
Mplayer as a frame server? Pipe to file?
By RogerTango in forum Video ConversionReplies: 2Last Post: 10th Sep 2011, 09:23 -
MPEG4 subtitles
By miconba in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2011, 00:11 -
Warning: Some steams in the media file could not be opened. ??
By solarblast in forum EditingReplies: 2Last Post: 16th Mar 2011, 21:08 -
unknown file
By nicgrosso in forum ffmpegX general discussionReplies: 27Last Post: 7th Apr 2008, 14:20 -
help w 'unknown' avi file
By rotuts in forum MacReplies: 7Last Post: 28th Feb 2008, 10:16
