I have movies on my computer that i would like to burn to a blank dvd-r.
I also made a video with Sony Vegas
I downloaded the trial of Sony Architect 5.0 and i get this error every time i try to put it on a disk. It dosen't matter where i try to save the file to, it keeps saying there is not enough room in the Temp files to burn it. I cleaned out the temp files and it keeps saying the same thing. I also have nero 7 and Max DVD burner and i cant get anything to play on this discs.I know it burns fine to the disc but the dvd player or xbox says ROOT twice and on the xbox it wont even play.
What i need/want is a program to where i can add a title/play botton and possibly credits but credits aren't absolutely necessary. I would like to continue to use Sony DVD Architect but i don't know why the heck it keeps saying there is not enough room in the Temp files.
Here's that screen shot (Ignore my emails on the left screen)
http://i15.photobucket.com/albums/a353/jeff_geck/untitled23.jpg
Any help would be appreciated because all i am having is trouble![]()
Do you have adequate free disk space on the temp folder (default is C: drive)?
You will need approx 18GB free. Or reassign temp file directory to the second drive.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Are you running FAT32? The size limit for a single file is 4GB! A 4.37 GB DVD ISO won't fit
no i am not running whatever fat32 is. It's not more than 4gb anywase.
the avi is 3.64GB and the mpg render is 699MB -
it also says something is outside of the view area...maybe this goofing everything
I changed the subject. Please don't just use problems and problems as it doesn't say anything.
DVD Architect Languages problem
By Compo in forum DVD RippingReplies: 2Last Post: 23rd Jun 2011, 07:47 -
DVD Architect 3.0 problem
By Jvance in forum Authoring (DVD)Replies: 3Last Post: 1st Jan 2009, 18:58 -
sub-menu problem in DVD Architect Pro 4.5
By younso in forum Authoring (DVD)Replies: 9Last Post: 3rd Jul 2008, 17:51 -
AC3 problem in DVD Architect
By blackberryf1 in forum Authoring (DVD)Replies: 0Last Post: 1st Mar 2008, 10:25 -
DVD Architect Audio problem
By Just Mike in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2007, 02:11
