Hello,
How come some Quicktime movies don't allow saving? I help produce a public access show here in Rhode Island called Sci-Fi Journal. I like to download movie trailers for the show. I usually save them and export them from Qtime to iMovie so I can add them to the show. Does anyone know how to get around this? I am using Qtime pro.
well sometimes you can look at the source code for the page that has the quicktime movie and find location of the movie file. Then I just take that and put it into an html file, load the html in ie and right click and tell it to save target as. This works on quite a bit of the movies that won't allow you to save, though there are one or two that I haven't been able to do this with.
Thanks Tigerwolf, I think I worded my original post wrong. I can download the movies to my hardrive and save them, but then some of the movies can't be exported to iMovie. I get a an error message that says "Movie does not allow saving". I can't copy, paste or export these files... Does anyone have this problem. One of the files that's giving me trouble is:
http://queenofthedamned.warnerbros.com/dld/clip6_hi.mov
I would appreciate any help thanks.
Tool to batch download, save and rename QuickTime stream files
By oediv in forum Video Streaming DownloadingReplies: 8Last Post: 24th Dec 2011, 18:24 -
Youtube HD mp4 file can't save as mov by quicktime
By yozloy in forum Video ConversionReplies: 3Last Post: 8th Jan 2010, 04:05 -
How to Save Youtube Movies to PC ?
By designbuyers in forum Video Streaming DownloadingReplies: 4Last Post: 3rd Mar 2008, 14:10 -
any quicktime movies go green
By matneaves in forum Software PlayingReplies: 4Last Post: 5th Aug 2007, 16:00 -
can't save as quicktime file? why not?
By kevs in forum MacReplies: 8Last Post: 5th Jun 2007, 14:46
