Maybe 2 or 3 months ago this burner just stopped reading burned cd's. It can read pressed cd's, burned dvds and pressed dvd's. Anybody has any ideas or maybe a fix? This is by the way a 4 years old burner.
Results 1 to 9 of 9
You might need a firmware update. It could also be bad file structure on the burned dvd's.
Believing yourself to be secure only takes one cracker to dispel your belief. -
please read my post again. I mentioned no problem with pressed cd's, pressed dvd's and "burned dvd's". Firmware has been updated sometime in 05. Could no longer find firmware updates from that site.Originally Posted by Dv8ted2
What brand of cd's are those burned cd's? What software did you use to burn those cd discs? It maybe time for a new dvd burner which is cheap these days.
This thread should go into the DVD REWRITER section. -
I have burned to many brands like sony, imation, fujifilm, memorex, tdk, etc. Those "burned cd's" can be read by my other pc. And sorry if this post is out of place.Originally Posted by budz
Since the burner is 4 years old, it is very possible that there is a film on the laser lens that is preventing it from getting a good read of the CDRs. What color is the dye on those CDRs? I recommend cleaning the lens very gently with a soft tipped swab moistened with alcohol, but you will have to remove the top cover of the unit to get access.
I had a laptop CD-RW drive burn and verify discs successfully, and then immediately tell me that the discs were blank afterwards
! I cleaned the lens - problem solved
. OH, and it did read pressed CDs without any problem before I cleaned the lens. Also, the discs that it burned and verified were perfectly fine and readable after cleaning the lens.
"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
I just wonder if it's easy to remove the "cover" of the unit. Is there something that I have to watch out for when doing this like springs or other objects popping out from inside the cover?Originally Posted by Number Six
Thanks for your suggestion. I'll let you guys know if I succeed. -
If those discs can be read on your other pc then it sounds like you need a new dvd burner. They're cheap these days at under $30.00 and at times you can free shipping from Newegg.Originally Posted by joy
Pioneer has a silver 115D drive for $34.99 and 1 cent shipping. You can always spray paint the drive black. The 115D drive is a good dvd burner. I've bought a few of them from Pioneer.
http://www.pioneerelectronics.com/PUSA/Products/HomeEntertainment/Blu-rayDisc+DVD/Blu-...5D+Silver.Kuro
Newegg has the following dvd burners with free shipping:
LG GH22LP20, $23.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136147
LG GH22LS30, $24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136153
Samsung SH-S202N, $19.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151155
Samsung GH22NP20, $22.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136144
Dvd burners with NO FREE SHIPPING:
Liteon DH-20A4P-04, $21.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106228
Pioneer 116D, $29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129023
The Pioneer 115D drive is the best out of those I posted. Just my 2 cents!
It isn't too hard to open the unit and get to the lens - there are no springs that will jump out. If you need extra help, please post again and I will give you step by step instructions. In my opinion, I feel that it is worth the effort to try and salvage this unit - I have 2 other NEC Burners, and they have been very reliable for me.Originally Posted by joy"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
Samsung SH-S203N SATA DVD Burner stops responding during burns?
By 1wheelken in forum DVD & Blu-ray WritersReplies: 84Last Post: 24th Aug 2009, 14:30 -
Fastest reading, most reliable DVD burner?
By Sephiroth666 in forum DVD & Blu-ray WritersReplies: 31Last Post: 8th Mar 2009, 13:45 -
AVCHD burned stops half-way through
By misfitzx138 in forum Authoring (Blu-ray)Replies: 1Last Post: 4th Jan 2009, 18:27 -
Burner stops while burning DVDs
By standalone in forum Authoring (DVD)Replies: 9Last Post: 21st Sep 2007, 00:48 -
Burned DVD reading as a blank
By trailofdead in forum MediaReplies: 3Last Post: 17th Sep 2007, 13:12
