Closed Thread
    Nov 2008
    Hello, I am using WinAVI Converter Pro. I am trying to convert an .AVI file to DVD format. The video converts just fine and everything is saved in the Video_TS folder, however there is an Audio_TS folder made, but with nothing inside, and the movie plays with no Audio.
    I have browsed the forum looking for solution and can't find any. I used the program "Gspot" to see if there were any problems and it said i had all the audio codexs. I attached an image below of the results.
    When I went to advanced options in in my converter to see what the audio type was it was as followed;
    Bit Rate: 1920000
    Type: AC3
    Thanks in advance.
    USA
    Do you have a Gspot screen shot of the WinAVI output? The one you show is a Xvid with CBR MP3 audio in PAL format which should be your original video. The PAL will have to be converted to NTSC for use on most US set top players. The AUDIO_TS is normally empty and you can ignore it most times.
    I'm no fan of WinAVI, so you might try another converter. It often has problems. FAVC or DVD Flick are a couple of freeware converters to try.
    And welcome to our forums.
    Just buy/rent Wanted on DVD instead.
