I have converted from m2ts into AVC MP4 and noticed that I have lines going across objects when there is movement?? Here is the video I converted.
http://blip.tv/file/get/Reyg-CristianTalkingAtZilkerPark648.mp4
I am using Sony Vegas 8 and here is a descrioption of the settings I used.
What do I need to do or change to not have those lines?Audio: 128 Kbps, 48,000 Hz, Stereo, AAC.
Video: 2.0 Mbps, 29.970 fps, 720x480
Use this setting to create an NTSC standard definition 16:9 Memory Stick compatible MP4 file.
Im basically trying to convert into a video file type that has excellent quality to play on computer when I email links to friends and families.
Looks like interlacing artifacts. You want to apply deinterlacing before you resize the video to 720x480.
followed the tip and still have lines.. should I have the video render into an avi and have it under the HDV settings? I changed the project settings and then went into rending and still used mp4 to render in?Originally Posted by Soopafresh
Problems importing MP4/AVC video in Sony Vegas Pro 9
By mltwitz in forum Video ConversionReplies: 1Last Post: 30th Oct 2011, 14:57 -
Sony Vegas 9 - MP4 AVC-1 - Sound but no video
By inocent in forum Newbie / General discussionsReplies: 3Last Post: 7th Jul 2011, 16:24 -
Render settings questions for MainConcept/AVC/AAC (*mp4) in Sony Vegas
By vid83 in forum EditingReplies: 10Last Post: 22nd May 2011, 03:55 -
Sony Vegas 8 convert m2ts to mp4???
By dilfatx in forum Video ConversionReplies: 11Last Post: 21st Jun 2010, 11:41 -
V_MPEG4/ISO/AVC to m2ts
By Bazza-61 in forum Video ConversionReplies: 9Last Post: 8th Oct 2009, 11:34
