does anyone know of any portable dvd players that do pal/ntsc playback?
like these below...not any particular brand just portable models in general
Portable players are typically not region free. So they only support the format for the region where they are purchased.
Google is your Friend -
If you have a region free pal dvd then the only way is to try it before you buy it,just like most regular dvd players they should play them but no guarantee.
I just bought jWIN JD-VD762 portable DVD player with 9" screen, USB 2.0 port, and SD/MMC memory card slot. It plays NTSC and PAL DVDs.Originally Posted by Moontrash
Here is the page on ABC Warehouse website:
http://www.abcwarehouse.com/product_catalog/pc_proddetails.asp~assort_id~1278~prod_ID~24972
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Portable DVD player. Region free. Pal/NTSC
By jtrinc in forum Portable VideoReplies: 2Last Post: 16th Aug 2010, 10:28 -
Do They Exist? Blu-ray players that supports NTSC, PAL
By xobituaryx in forum DVD & Blu-ray PlayersReplies: 21Last Post: 26th Feb 2010, 16:03 -
Format free DVD-R (plays in both PAL and NTSC DVD players)
By Disco Makberto in forum Newbie / General discussionsReplies: 6Last Post: 22nd Nov 2007, 01:34 -
Portable NTSC & PAL TV?
By Disco Makberto in forum Portable VideoReplies: 12Last Post: 14th Nov 2007, 23:31
