Since we are on this subject ... about blue screens of death ..........
See the thread posted >> https://forum.videohelp.com/topic360260.html
......... where is a good website to go for reviewing the code that appears for figuring out what is wrong.
I've got a laptop ... a Dell Inspiron B130 ... and just when it displays the Windows XP loading up ... goes into blue screen with the message info.
I haven't messed with this Laptop ... got it used on Ebay during this past summer and I figured I should check it out.
It wasn't doing the blue screen when I first received it and stuck up on a shelf for safe keeping. I took it down yesterday and it now it is doing the Blue Screen of Death.
I went into safe mode and it does it there too. I decided okay ... I will re-install Windows XP on it.
I got to the part where it loaded the files and then wanted me to hit enter ... I did and it did the blue screen again.
I didn't expect to see the Blue Screen when going to Boot to Disk mode and reinstalling Win XP Home.
It says >> Page_fault_in_nonpaged_area
info at bottom says >>>
Technical Information:
*** STOP: 0x00000050 (0xC2DC0000, 0x00000000, 0x805361E3, 0x00000000)
I've got one extra stick of ram I can try from a different source and I have extra laptop drives that are most likely compatible.
There is an extra Inspiron B130 here but it belongs to a friend and he got it for $10 bucks at a Flea Market sale in Fresno CA. Since it uses DDR2 memory ... I was not able to test it during that time.
But since then ... a few months ago ... I decided the Inspiron B130 was not to bad ... so I got one on Ebay.
I figured that since the new laptops have DDR2 ram I should have one around that uses DDR2 ram so I can use my laptop to see if the person with a messed laptop has good ram or bad ram ... well crap ... my laptop is screwing up.
I also bought a few months ago ... a Inspiron 1520 ... and reinstalled Win XP on it ... I like it ... it stays in my bedroom ... it works fine and does use DDR2 ram ... has a Intel Dual processor in it. I haven't loaded it with all the bells and whistles I usually load up in my laptops ..... yet![]()
The other posted thread mentioned going to ...
http://www.geekstogo.com/forum/Windows-XP-Blue-Screen-Death-STOP-Codes-t43519.html
My BSOD code was mentioned there ... bad video ram or system ram ... well I hope it is system ram ... video ram could be a problem ... but dont the system for laptops use system ram for video ram.
I hope the extra stick of ram I do have will help me figure out the problem.
DVD Dell Inspiron writer drive .. blue screen
By holeepassion in forum DVD & Blu-ray WritersReplies: 14Last Post: 4th Sep 2011, 21:30 -
Blue Screen of Death (BSOD)
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Dec 2009, 05:31 -
Recovery Files/Blue Screen Of Death!
By Squid_uk in forum ComputerReplies: 37Last Post: 19th Nov 2008, 18:24 -
By Squid_uk in forum ComputerReplies: 15Last Post: 31st Mar 2008, 15:35 -
Blue Screen of Death while converting .avi to DVD
By robwbright in forum ComputerReplies: 7Last Post: 5th Oct 2007, 21:53
