ok so im using the latest gotsent to convert mkv to mp4.
now im trying it get to play on psp. but whenever i convert the mkv. even when enabling "re encode: h264".
was wondering if some one could help.
or maybe if some one has a way to make the mp4 psp computable without re-encoding ty.
thanks but can something convert mkv > mp4 psp without re-encoding the whole thing?.
Alright here it is, its the movie 300 in mkv format.
Format : Matroska
File size : 396 MiB
Duration : 1h 49mn
Overall bit rate : 508 Kbps
Encoded date : UTC 2008-05-30 05:39:21
Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 49mn
Nominal bit rate : 376 Kbps
Width : 640 pixels
Height : 272 pixels
Display aspect ratio : 2.35
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.090
Writing library : x264 core 59 r859M ce13bb6
Encoding settings : cabac=1 / ref=8 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=6 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=12 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=0 / decimate=1 / mbaff=0 / fgo=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=376 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
Language : English
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : No
Codec ID : A_AAC
Duration : 1h 49mn
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
And wanting to convert to mp4 [psp computable] without having to encode the video again, if it converts audio it is ok. just looking for the LEAST time consuming way. So just a little help and little guidance so I can do it solo in the future.
And thanks baldrick for helping out. =D -
You're probably going to have to re-encode the video stream. I'm not sure about the PSP's maximum resolution (if you're NOT going to hook it up to a TV screen) - it's either 320x240, 368x208 or possibly up to 480x272. If you DO connect it to a TV, it supposedly supports 720x480.
If you're wanting to convert in the least amount of steps and with the least amount of quality loss, why not re-rip from your original DVD, and use something like XVid4PSP to convert that directly to PSP MP4 format?If cameras add ten pounds, why would people want to eat them? -
I only have the .mkv nothing more of it. And I usually dL as .mkv's since its a small format with hq. And PSP supports up to 420x272. Just seeing if maybe bald may know a way. =]
best mkv to psp and ps3 video converter
By ratboys in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2010, 20:21 -
MKV > PSP.
By 4ce in forum Video ConversionReplies: 10Last Post: 24th Dec 2008, 18:57 -
How to convert MKV to PS3 or PSP
By rjsax21 in forum Video ConversionReplies: 1Last Post: 12th Aug 2008, 21:11 -
[Help] How could i convert a MKV into a PSP-playable video file?
By rustix in forum Video ConversionReplies: 4Last Post: 12th Jul 2008, 10:23 -
help converting MKV to MP4 for PSP with subs.
By jag125 in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 04:08
