Hello.
I have VLC Media Player. I am playing a DVD movie. I am using VLC Media Player to capture what is on the screen and turn just that one image into a file.
COULD YOU PLEASE GIVE ME A GUIDE FOR THE COMPLEATE IDIOT ON HOW TO CAPTURE THE IMAGE ON THE SCREEN? I have not been able to do it, yet!
If you're using one of the more recent VLC versions, select Snapshot from the Video menu. I think the 0.8 and earlier versions had it under the File menu. (Keep in mind that the 'regular' download of 0.8.6 had a bug in the snapshot routine, if I remember correctly. There's a link to a fixed version somewhere on the VLC forums, or just update to the current 0.9 version.)
There should also be some settings in the preferences (output directory, output file format, etc.) that you can also set, but I haven't yet located them in the current version (only did a quick run through the preferences, just now
(edit: Tried a snapshot with 0.9.6; it saved the screen capture to the My Documents\My Pictures directory, in JPEG format.)If cameras add ten pounds, why would people want to eat them? -
You can also press Shift+s to take a snapshot. The function can be assigned to another key via Tools -> Preferences -> Hotkeys -> Take Video Snapshot.
You can change the default directory and file type via Tools -> Preferences -> Video -> Video Snapshots...
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
Idiot's Guide to Encoding
By sharpfocus in forum Newbie / General discussionsReplies: 4Last Post: 11th Sep 2011, 19:59 -
display size between windows media player and VLC player
By kool_k in forum Software PlayingReplies: 4Last Post: 6th Aug 2011, 15:18 -
Better media player than VLC?
By meneedit in forum Software PlayingReplies: 5Last Post: 16th Nov 2010, 07:32 -
VLC Player - Code Needed For Remote
By John_Jordan in forum ProgrammingReplies: 2Last Post: 15th Jan 2008, 21:13
