I've owned a ConvertX PX-TV402U which can capture compsite audio, video, and s-video at 720x480 in MPEG4 or DIVX. However, I was told to get best quality from VHS capture (i have very important VHS tapes to digitize), I need to capture in 720x480 using Lagarith or high-tech codecs like that. Thus, I had to purchase a capture card. I just purchased the ImpactVCB from Hauppauge but I just realized it doesn't have compsoite audio. In addition, I'm unable to capture any more than 320 x 240. Well actually I can capture 720 x 240 but 240 is max. thats crazy
First, can this be fixed?
If not, I need a capture card with s-video and compsoite Left Right audio that works with virtualdub and can capture 720 x 480 guaranteed with any codec.
any help is appreciated
i have xp sp2
For the audio, just plug your VCR audio into your computer audio card or line-in socket. It should show up in the recordings after you adjust your audio card settings. You will see that in the 'system requirements' for the card: http://www.hauppauge.com/site/products/data_impactvcb.html
thks...i just read u can get a rca to 3.5 mm converter but some complain of sync problems when you use a separate audio card from video capture card
but more importantly i need a recommendation of capture card that is available to buy on ebay or major sites that works with virtualdub and captures 720 x 480 in any compression -
Use virtualvcr,better than vdub for capturing.
VirtualDub Capture Pin problem.. (EasyCap) [SOLVED]
By muzzmikkel in forum Capturing and VCRReplies: 0Last Post: 22nd Jan 2012, 11:05 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Capture card problem
By Phaze72 in forum Capturing and VCRReplies: 7Last Post: 13th Apr 2008, 17:31 -
Looking for a quality capture card fully functional in VirtualDub
By zeug in forum Capturing and VCRReplies: 2Last Post: 20th Nov 2007, 00:35 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
