  1. I am using the new version of tmpenc and like the wizard capability of showing used and free space on a disk for a paticular file with pinnoy's template. Is there any way to add an unlocked template to the wizard to use this file size calculator?
  2. It basicly just gives you the maximum file size you will get using the specified bitrate, and when it's VBR, it simply says 1min will take upto ??? mb.
    Like with my SeVCD/SxVCD Templates, since the bitrate is identical to VCD (1150kbps) and that gives 1min = 10mb, then it will say that the resulting file size will take maximum 1min upto 10mb.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
