hi. Pinnacle has a few HDTV tuner devices for pc's. At Best Buy for a black friday sale, they have one that is USB, but here's my question. The minimum requirements for it to work is having a Pentium 4, 2.80ghz CPU (or an Athlon64 CPU), and 512mb of ram.
Does anyone know if these are a definite requirement? Has anyone ever used such a device on a 1.80ghz machine that had 512mb and it worked? For $59.99, it looked pretty bitchin! I will probably buy a new, modern laptop next year that will allow the HDTV tuner to work, IF it would never work with a 1.80ghz machine, which i currently have.
ATSC is already compressed as MPeg2/AC3. An HD tuner just feeds the decoded MPeg-TS/PS stream to the drive system. The CPU spec is needed to preview or play the file. The display card can assist with MPeg decode and rescale. Your system is probably not up to the task. Try to obtain some ATSC HD streams to test your system.
Make sure the tuner stick supports QAM decode if you expect to use it with a cable system.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
HDTV ATSC Tuner Quality
By sambat in forum DVB / IPTVReplies: 5Last Post: 24th Nov 2011, 16:57 -
hdtv tuner for over the air channels
By carlos28355 in forum DVB / IPTVReplies: 7Last Post: 21st Jun 2010, 19:07 -
HDTV Tuner
By olyteddy in forum Capturing and VCRReplies: 0Last Post: 25th May 2009, 18:59 -
Can you explain to me what a HDTV with QAM tuner is?
By davidsama in forum DVB / IPTVReplies: 1Last Post: 30th Sep 2007, 16:17 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
