I'm having a problem with audio in DVDs that I make. It has a buzzing type background noise throughout the whole DVD, I never had that buzzing type audio background noise in my DVDs like I do now. Do you think it could mean I need new speakers and an audio cord? I notice when I turn my speakers on, it makes a similar buzzing noise...I don't know how to fix it.
could be a ground problem. does it sound like a constant 60 cycle hum? you can try reversing the wall plugs or running a ground wire to connect all devices. also make sure to use 3 prong plugs whenever possible and check the outlets with a testing device if possible.
I can't really describe the noise other then just a constant buzz..how would I run a ground wire and what kind of testing device would I use? I've never done that before. Do you think it could mean I need new speakers and an audio cord connecting the vcr to the computer?
a constant buzz sounds like a ground hum. it's fixable if you can find the ungrounded device.
testing devices can be found at home depot/radio shack type places. it's just a little dongle you plug in to the outlet and it tells you if it's wired properly. like on this page.
http://www.acmehowto.com/howto/homemaintenance/electrical/outlettest.php
you can try using the center screw of a power outlet to run a ground wire from, or the metal exterior screw connector of a cable tv line.--
Video where speech is quiet and noises are loud
By A Traveller in forum Software PlayingReplies: 14Last Post: 12th Oct 2011, 11:39 -
Strange audio shift when using other audio track than default
By Heliooos in forum DVD RippingReplies: 2Last Post: 25th Mar 2010, 00:46 -
reduce background noises in a movie clip
By tomchook in forum AudioReplies: 1Last Post: 5th Jun 2009, 05:55 -
Hard drive noises?
By Hank Kinsley in forum ComputerReplies: 6Last Post: 12th Dec 2008, 06:58 -
noises in audio
By Driftking978 in forum AudioReplies: 1Last Post: 29th Apr 2008, 10:51
