If I am using images in after effects as layouts and logos, should I encode the images in adobe illustrator, .ai, files, png, psd or gif?
I understand that all 4 files can produce a transparency; however, is the quality enhanced depending on which one you choose. I also know that you can manipulate the psd and the ai files alot better than the other two but what is the real difference in manipulation between these 2 formats. I read some where that you can copy and paste the vector path points from illustrator to after effects. Is this true
Thanks in advance
How's My English?
gif is rubbish as it has limited bitdepth and requires dithering.
AI is only appropriate if you are working with vector illustrator files.
PSD is great if you need to preserve layers and layer effects, but sizes can get big.
png is a good compromise if you need colour depth, transparency, but not layersRead my blog here.
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 12:00 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 9th Aug 2010, 23:16 -
Youtube picture quality
By Juc1 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2009, 20:36 -
picture quality
By nexous in forum RestorationReplies: 4Last Post: 18th May 2007, 04:03 -
Need Quality for keying in After Effects
By aburger in forum ffmpegX general discussionReplies: 9Last Post: 4th May 2007, 16:51
