Hello, I tried the following region free procedure.....now the dvd player does not work
Region code hack posted by turtax101, April 26 2005:
1.Turn on your DVD player
2.Open disc tray either using the EJECT button on the Player or the OPEN button on the remote
3.Press 28126
4.A menu should pop up, press ENTER until 9 appears
5.Your DVD player is now region-free (you can play any countries DVD's)
Aside from removing power for several minutes, your only option is to claim ignorance and have it repaired/replaced if it's under warranty. Otherwise, time for a replacement.
Google is your Friend
Samsung c500 reset ***HELP***
By Samsungc500 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Nov 2011, 19:51 -
Hard reset for BDP3000
By alexh110 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Oct 2011, 10:37 -
vsRip will not reset timing
By kenryuakuma in forum SubtitleReplies: 3Last Post: 26th Sep 2011, 18:45 -
How do I reset the code?
By deltarory in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2010, 05:35 -
BD rebuilder worked; how to reset the beta
By TomBud in forum Blu-ray RippingReplies: 9Last Post: 3rd Jan 2010, 16:30
