After two days of searching arround the www. for a good "how to" for remuxing MKV files . I found only useless and complicated ways and noneone really pinpointed the best way .
Everyone had thousend of diffrent ways and programs that they use and all of them are waist of time , I have tried every single program out there for a good and fast conversion none of them does the JOb...
EXCEPT MKV2VOB.. I stumbled upon this program by mistake as it wrongfully is placed in a wrong shelf. Its suposed to be only for PSP conversion .... But this is utterly and completly wrong ..
MKV2VoB does two things which none of the other programs do , it demuxes transcodes and remuxes the mkv file in a new container ,, which is Brilliant!!!
But this program has a brlliant function which people miss, It has a automatic transcoding option. The program detects if the mkv file needs transcoding or not to be played on THE PSP!!!
Most of the time it will not transcode which will lead to a very fast remuxing from mkv to vob but these files cant be palyed on media players.
!!!!BUT!!!!![]()
If you want this program to remux any mkv file to be palyed on any player out there, the only thing you need to do is to set the TRAnscoding option on "ALWAYS" then voilamkv2vob will demux transcode and demux the mkv file to a recognised mpeg2 or xvid which can be in a new container without any quality loss or audio loss.....
Even though the size of the file will decreas the quality is still very high . I used mkv2vob for remuxing a blueray rip of wall 1080p x264 , I have a Fullhd tv 1080p my media player is 1080p, audio is via optical cable 6channels .
The pictures is absolutly brilliant not a single pixel or anything else is visible the sound is oustanding......
Conclusion:
1.Downlaod MKV2Vob
2.add your file
3.change the "transconding" setting to "Always"
4. Wait
5.Enjoy
6. Donate MOney to the Guy who did this application...."3r1c"
What are you using to play this back on? You say "HDD player" which doesn't really say much as that could be any number of things.
Best Blu Ray Player to play 3D MKV (DTS audio) files off my USB HDD?
By Freaz in forum DVD & Blu-ray PlayersReplies: 18Last Post: 28th Apr 2012, 23:15 -
Fastest & easiest way to convert files from dvd to upload to Youtube?
By scarypoultry in forum Video Streaming DownloadingReplies: 2Last Post: 6th Jul 2010, 03:49 -
Easiest, fastest way to convert MKV to Blu Ray with 1080p aspect ratio
By jfk8680 in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Apr 2010, 00:07 -
How to join m2v, the easiest and fastest way?
By hanugro in forum EditingReplies: 10Last Post: 4th May 2009, 07:32 -
Easiest and fastest ripping prog?
By Valioser in forum DVD RippingReplies: 1Last Post: 5th Mar 2009, 18:57
