Hi
The subject sort of says it all. Just installed FFmpegX. Installed all binaries. When I try to convert a FLV to MOV, the result is a 0 Kb file.
Can anybody help?
J.
We really need a sticky on what info to provide for requests like this. "It didn't work" conveys too little information for us to be of much help, except by luck.
Please post the contents of the information log (click on the blue 'i' in ffmpegx's progress window). Hopefully, it will contain information that we can use to help debug your problem.
tomlee,
Thanks for replying. Any help will be greatly appreciated. I'm trying to give my students in an anger management course a little fun!
Here's the log:
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Fri Nov 28 15:52:39 EST 2008
Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 29.97 (30000/1001)
Input #0, flv, from '/Users/macbook/Knapp, LMSW/anger management/teen/YouTube - Crazy man attacks teen.flv':
Duration: 00:01:29.4, bitrate: N/A
Stream #0.0: Audio: mp3, 22050 Hz, mono
Stream #0.1, 29.97 fps(r): Video: flv, yuv420p, 320x240
Codec type mismatch for mapping #0.0 -> #0.0
The "codec ... mismatch" message suggests that you should select "invert mapping" in the audio options. Give that a try and see if it solves your problem. It may introduce new problems (flv is implicated in many of the problems brought up on this thread, as a quick search will show), but one onion-layer at a time...
Fyi: It's also a good idea to avoid the use of spaces, commas and other "special" characters in pathnames. Some modules used by ffmpegx are intolerant of them (even though the Mac OS itself may not have a problem, ffmpegx makes use of routines adapted from the unix world). You might want to modify your filenames/pathnames accordingly, just in case.
tomlee,
That did it!
Thanks so much! It's so great that this forum exists and that experienced users like you are willing to help noobies like me.
Thanks again!
J.
John M. Knapp, LMSW
Therapist. Cult Recovery Counselor. Coach
http://KnappFamilyCounseling.com/
Issue converting a .mov to a .flv
By bopdro in forum ffmpegX general discussionReplies: 1Last Post: 5th Mar 2009, 12:15 -
question about converting mov file to mp4
By cduval04 in forum Video ConversionReplies: 2Last Post: 10th Jan 2009, 20:34 -
Another noob: Flash to MOV: 0 kb file size
By younkint in forum ffmpegX general discussionReplies: 2Last Post: 28th Nov 2008, 21:26 -
Help converting .MOV to .FLV
By fritzthird in forum ffmpegX general discussionReplies: 2Last Post: 19th Apr 2008, 13:00 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39
