Sorry for a late post on this subject but yes the Black Magic Intensity Pro does indeed work with FME 2.5 and FME 3.x. I use mine all the time for h264 encoding of WMVHD broadcasts from my xbox 360 to my justin.tv. I have no problems with it and have even put together a help video.
I have discussed this in the Adobe forums as well located here http://forums.adobe.com/thread/209495
One thing to note, not a lot of people did there homework before buying this card. The Audio capturing abilities are not there due to the device not having the proper hardware on it. THis card is awesome and nearly flawless everytime. When i do have problems with it it is due to my error ususally in settings, not the cards.
Thanks,
Steel
P.S.
I can be contacted at steelahlive@comcast.com for questions in regards to the Blackmagic Card or you can check out capture's I've done with my card on my youtube / justin.tv sites.
Results 31 to 33 of 33
steelahlive,
I tried emailing you at the address you have listed in your post, but the email was returned. I am dealing with the audio issue with my Blackmagic Intensity Pro and FME, and would like to configure my card to work...can you please post a step-by-step method to configure this, or provide a new email address that I may reach you at?
Thanks!
Blackmagic Intensity Shuttle
By mayhampixi in forum Capturing and VCRReplies: 5Last Post: 11th Nov 2013, 20:11 -
Blackmagic Intensity Pro.
By liamb96 in forum Capturing and VCRReplies: 8Last Post: 18th Oct 2010, 16:20 -
Blackmagic Intensity Pro 3.5.1
By Lynas in forum Capturing and VCRReplies: 24Last Post: 10th May 2010, 13:28 -
Blackmagic intensity pro help
By Smify123 in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2010, 11:19 -
BlackMagic Intensity Pro
By Richintx in forum Capturing and VCRReplies: 0Last Post: 23rd Jan 2010, 09:43
