    Aug 2008
    Norway
    What converting software are you using? Am mostly looking for a software that can take any codec/filetype.
    USA
    Doesn't exist that will convert any codec/filetype. And what quality do you want? The closest I know of is SUPER, but I would only use it for lower quality conversions.
    If you want higher quality and more control, the individual programs are a better choice.
    I use VirtualDub (Mod), Ripbot264, ConvertXToDVD, FAVC, AVISynth, and DVD Shrink regularly, along with quite a few other programs that are sometimes needed for the encoding/conversion/authoring and other video processes. A lot depends on what your final output type is, along with what your source video type is.
  3. Member olyteddy's Avatar
    Dec 2005
    AVI DeMux is my usual weapon of choice.
    Apr 2004
    Miskatonic U
    AVI Demux, Xvid4PSP, AutoGK, FAVC, DVD Flick. Depends on the need. Horses for courses is my motto.
    Read my blog here.
    Dec 2006
    Asian heart
    Like olyteddy: My first choice is Mediacoder, then VirtualDub. That's all I want to convert, transcode and edit video files.
