I need to video tape some projector slide presentations. When I tape the slides shown on the screen, the VTR continously shifts the color from an overall reddish tint to bluish tint and then back again. IT's as if the VTR is trying to make an automatic adjsutment for something and can't stop. But I can't figure out what autoadjustment to turn off. Setting white balance to fixed doesn't help. The VTR works fine except wihen taping slides projected on a screen.
I've tired several diff VTR s and the results are the same.
Any thoughts?
tia
Scott Hieber
"why doesn't my car run?"
you'll need a lot more info in your post to get an answer...be very specific with your equipment and technique -
You'd be better off scanning the slides and recreating the slide show in editing software.
Buy My Books -
"projected" as in 35mm transparencies, or "projected" as in MS power point, PC, VGA-type projector?
If the latter, I bet it's the colour wheel (DLP-based tech?) - the RGB colours on screen are alternating thousands of times per second - too fast for the human eye to detect it, but such that a fixed speed shutter in a camera can catch slightly more of one colour than another, leading to perceived colour shift.
A longer shutter speed might help in this case. A direct screen grab, directly inserted into the video later, would be better.
Cheers,
David. -
This makes snese since it happens with diff brands of cameras when taping digitial projectors (power point and such) and some do it worse than others and shift at diff speeds. If I had the the slides on didsk and didn't have to tape them, that would certainly be preferable but not always an option. So I'was hoping to conquer the color shift prob.
I'll see what I can do about shutter speed and meanwhile, any other suggestions welcome.
thanks,
sh
Originally Posted by 2BdecidedScott Hieber -
Since these are slides, just find one frame where the colors are right and stretch that to the desired duration.
ffmpeg output prores causes color shift
By liutszho in forum ffmpegX general discussionReplies: 1Last Post: 4th Jan 2012, 23:22 -
connecting laptop to projector for video presentation-hookup issue
By geminidreamer in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2010, 19:51 -
ADVC-55 and color shift?
By pgoelz in forum Capturing and VCRReplies: 28Last Post: 16th Mar 2010, 18:10 -
Combining Flash projector .exe presentation with DVD quality video
By alexmc in forum Authoring (DVD)Replies: 3Last Post: 1st Feb 2010, 12:44 -
Color shift in ffmpeg X - ffmpegX native color space and gamma?
By rbot1980 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Feb 2009, 22:16
