i have a dvd when i try 2 rip with smartripper 2.41 it says files are locked how u get by that???
When Smart Ripper loads, it searches for ASPI, does it find it in your case ?
without the ASPI it makes it more difficult for Smart Ripper to accuratly copy the DVD files.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Did you unlock the drive by first playing a couple of chapters of the dvd, you must play it and get past all the crap at the start and actually into the movie for a few seconds, then close your player and start smartripper, should be unlocked then, if it doesn't then as sefy says you are missing your aspi drivers, you can download and run force aspi to enable then.
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
how to rip the dvd ????
By kathir. in forum DVD RippingReplies: 10Last Post: 29th Jul 2011, 08:44 -
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 26th Sep 2010, 23:52 -
How do i rip out a dvd?
By beecho in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 21:20 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28
