I have the latest firmware version 31 from the Philips website. My drives are NTFS and FAT32, neither works with my docking station. Do you guys think the docking station is the issue?
Any advice would be appreciated. Thanks in advance!
a hub needs a computer to work properly. whatever you plug into the 5990 should be directly plugged in. try something like an ide/sata to usb connector.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=50002177%2040000353&Descri...&name=Rosewill--
Thanks aedipuss, but I don't think that's my problem. My docking station is plugged into the player via USB. Isn't a docking station essentially the same thing as an external case? The difference is that the docking station allows swapping out drives easily. So I'm not sure what the problem is here.
the docking station must not be the same as a conversion cable, or the 5990 wouldn't think it's a hub.
I have a seagate 1TB drive, 3.5" in a coolermaster external enclosure with it's own power source. I've formatted it to Fat32, and I get the same message, that the USB hub is not supported. Is this adapter the thing I need to get it working?
vobblanker error "ifo has more than one pgc, not supported"
By patz in forum Authoring (DVD)Replies: 15Last Post: 26th Apr 2012, 02:58 -
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 03:03 -
Visual Hub / DVD / Where is "force anamorphic" ?
By webstar in forum MacReplies: 2Last Post: 30th Jun 2010, 05:13 -
How can I fix a "interface not supported" error in avi2dvd?
By Han Solo1 in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2009, 15:51 -
philips dvp5992 displays "Video Resolution not Supported"
By mike69 in forum DVD & Blu-ray PlayersReplies: 20Last Post: 30th Dec 2008, 10:17
