what is the appropriate dvd bitrate?
upper left of this site page. what is: dvd.
Depends on the resolution, the source type and how fussy you are regarding quality.
Lower resolution video looks fine at a lower bitrate, higher resolutions need higher rates to keep quality.
Shakey handheld sources need a higher bitrate.
Marginal quality video can look bad on a big screen HDTV but Ok to someone else viewing it on a small CRT."Art is making something out of nothing and selling it." - Frank Zappa -
ZippyP.
Posted: Nov 26, 2008 20:50
i want to keep the quality or at least not lose so much of it -
1-1/2 to 2 hrs per dvd, eg 4800 to 6500 kbps is good. Use a bitrate calculator, see the Tools section.
ZippyP.
Posted: Nov 26, 2008 21:44
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
