Hello all
I am trying to gather some information as to how would someone get this done.
Keep in mind, I am looking to find some examples so I can see if it can be captured, now how to do the forum.
I am going to be watching some videos that will be posted in a forum, they are supposed to be a HD video streams, and I am pretty sure they will be embedded on the forum.
Since its not a live stream (because you will be able to post questions about it in the forum below) I am sure it is not live and they are claiming it is a rebroadcast.
My question is, how easy will it be to capture that onto my PC?
video lenghts will be from 2 to 3 hrs long, size of the video will be 1024x768.
I have DownloadHelper installed on my Firefox, and I am looking at couple of other ones. But since I dont know how that will be posted on the forum its a little hard to test it correctly.
The forum they are using is the vBulletin.
Thanx
Spooky
How to stream a video stream.
By chackonman in forum Video Streaming DownloadingReplies: 2Last Post: 12th Mar 2012, 14:51 -
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
Is it time for a new forum dedicated to 3d video?
By yoda313 in forum FeedbackReplies: 18Last Post: 10th Apr 2011, 11:51 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 12:01 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27
