Forgive the horrible noob question as I know nothing about subtitles or anything related to them...
Basically I'm wondering how I can get .ass subtitles to work with .wmv files? I've been watching some subtitled shows which were .avi but the 1080p versions are .wmv and the subtitles don't work with that. I have CCCP installed for codecs. What am I missing or doing wrong?
No, I assumed CCCP contained all the necessary drivers... which it probably does but for some reason it's not associating the .ass subtitles with anything other than .avi. I can get it working by changing the extensions to .avi but that's tedious and can sometimes cause playback issues. Not to mention I don't want files having the wrong extension.Originally Posted by poisondeathray
I just installed VobSub and it didn't change anything. The .ass files don't play with the .wmv files. -
What software player? It works with directshow players like MPC
Do you see a green arrow icon in the right lower corner taskbar when playing the video? Right click it and enable subs
They have to be in the same directory with same name eg.
file.wmv
file.ass
Other options are to use KMplayer or SMplayer to playback, which should support it without directvobsub -
Yes my files are in the same directory with the same name, everything always worked fine with .avi files. The green arrow would appear (with CCCP installed) for .avi files being played in anything (I usually use Winamp though I don't know what's best for good 1080p playback). I guess I'll try MPC but I doubt that will work.Originally Posted by poisondeathray
EDIT: I checked and yes CCCP does contain the files of VobSub and THANK YOU MPC actually does work. It probably has the least bloat as well so it's likely the best for playback but I would still like to find out why it doesn't work in other players if it's not .avi...
Subtitles get embeded in WMV when converting from MKV using Format Factory
By PlayWithFire in forum Video ConversionReplies: 10Last Post: 12th Jul 2012, 10:22 -
.ass subtitles encoding help
By B Boy Rock in forum SubtitleReplies: 6Last Post: 16th Aug 2010, 13:02 -
Hardcoding ASS Subtitles
By roflwaffle in forum Newbie / General discussionsReplies: 0Last Post: 13th Jul 2010, 14:45 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
Question: How to adjust the position of ASS subtitle format?
By FulciLives in forum SubtitleReplies: 2Last Post: 22nd Jul 2007, 00:24
![Computer details: Vista Ultimate 64 SP1
E8400 @ 4.3GHz
2.08TB [300GB+500GB+2x640GB (RAID0)]
4GB (2x2) DDR2-1000
BFG 8800GT @ 765/1856/2100
Gigabyte GA-P35-DS3R rev. 2.1
Comp](/images/buttons/computer.gif)
