Hey, I'm backing up some DVDs to DL DVD+R (don't worry, I'm using Verbatim). Anyway, I'm using IMGBurn to place the layer break, but are the options with the "SPLIP" column saying "No" better than the ones saying "Yes?" There are like 5 options that say Yes and one that says No. But it looks like the one that is marked No is at the beginning of an episode (it's an episodic DVD). Could that cause a problem? Can somebody help? Thanks!
Use the PcgEdit + ImgBurn method. No more guessing required.
There's a guide for it here on this site.Want my help? Ask here! (not via PM!)
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
ImgBurn can't find a place for a layer break
By PhoneMatt in forum Authoring (DVD)Replies: 13Last Post: 27th Oct 2009, 07:20 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26 -
DVD+R DL layer break problems
By The-One in forum DVD RippingReplies: 1Last Post: 21st Oct 2007, 16:34 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 13:27
