i have been attempting to trim sections out of a 720p encoded mkv file i have. when i do, the audio is out of sync with video by almost 2-3 seconds. i have a quad core cpu, 4gb ram, nothing running in background, vista 64 bit os. i have several mkv files encoded the same way and they have the same issue. the video plays fine on my pc with no issues. i have researched online for hours for an alternative program and everything points back to avidemux. i have included the details of the file below that i am having issues with. any help that can be offered is greatly appreciated.
General
Complete name : E:\Video\myvideo.mkv
Format : Matroska
File size : 1.46 GiB
Duration : 1h 6mn
Overall bit rate : 3 152 Kbps
Encoded date : UTC 2008-10-19 15:16:19
Writing application : mkvmerge v2.0.0 ('After The Rain Has Fallen') built on Jan 13 2007 19:58:56
Writing library : libebml v0.7.7 + libmatroska v0.8.0
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@3.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 6mn
Bit rate : 2 634 Kbps
Nominal bit rate : 2 764 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.100
Writing library : x264 core 65 r999 cc51047
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=2764 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 6mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Results 1 to 1 of 1
VLC not playing mkv(720p, h264) files smoothly?
By swalih in forum Newbie / General discussionsReplies: 15Last Post: 9th Mar 2012, 20:31 -
1080p vs 720p MKV Files
By esabet in forum Newbie / General discussionsReplies: 15Last Post: 24th Dec 2010, 20:27 -
2 x 720p AVI with DTS - need 1 x 720p MKV with AC3
By snadge in forum Video ConversionReplies: 2Last Post: 25th Oct 2009, 13:38 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 20:23 -
Players that can play 720p mkv/h264 files.
By alkalinelito in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Feb 2008, 09:13
