Hey
Can anyone recommend a Oneforall remote that is out on the market right now that will allow me to hack my Sony BDPS550 Profile 2.0 Blu-ray Player?
I just want to make sure it will work. The cheaper the better; I'll only be using it once!
Much love
Mark
The hack instructions should list which remote was used. If not, I know one of the Sony hacks used this one: OneForAll URC-7040
Google is your Friend -
I just purchased a One For All URC-7562 universal remote and it unlocked the DVD player perfectly.
Thanks guys
Can you confirm the model number (located inside the battery cover) of the OneForAll remote you used? I have a URC-7562 B00 which does not allow me to unlock the BDP-S550.
One other thing I noticed while completing the instructions was that they state keys 1, 2, 3, 4, 5 will flash - mine do not have the ability to flash I believe.
Any other suggestions as to what I should be doing would be appreciated.
Thanks!
Remote needed
By IMREW in forum ComputerReplies: 3Last Post: 27th Mar 2010, 08:19 -
remote codes?
By pamelajaye in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2008, 11:45 -
Re-program your remote
By zoobie in forum ProgrammingReplies: 0Last Post: 4th Nov 2008, 13:28 -
Remote
By WildParadise in forum Media Center PC / MediaCentersReplies: 14Last Post: 24th Apr 2008, 10:10 -
remote
By rtrg in forum Newbie / General discussionsReplies: 1Last Post: 1st Apr 2008, 13:46
