When I open Vegas and want to render to mp4 it only gives me option to do it at the ipod resolution??? Is there a way around this? Also I went ahead and did that at the highest quality and got an mp4 video wth ipod resolution and there was "ghost" images throughout the whole video.. What settings do I need to have it stop doign that?
I know lots of questions.. but I hope somebody can help me out. Want to convert my son's home movies to upload them to blip.tv
Results 1 to 12 of 12
you should get 3 drop down settings for mp4 - default and 2 apple ipod. if you use the default you can change the resolution to whatever you want in the custom video tab.
Wish I knew about those apps yesterday lol will install and try em out..vegas can just sit back for the nifty editing stuffOriginally Posted by Baldrick
going to try it out.. and get back with you.. the render process takes forever..Originally Posted by aedipuss
This is the info I got from mediainfoOriginally Posted by poisondeathray
Code:General ID : 0 Complete name : file directory Format : BDAV Format/Info : BluRay Video File size : 53.0 MiB Duration : 26s 247ms Overall bit rate : 16.9 Mbps Maximum Overall bit rate : 18.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Duration : 26s 233ms Bit rate : 15.8 Mbps Width : 1920 pixels Height : 1080 pixels Display aspect ratio : 16/9 Frame rate : 29.970 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 26s 247ms Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Video delay : -67ms Text ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Video delay : -133ms
This looks like it might be from an AVCHD camcorder, probably a Sony variety ?
The "ghost images" you mentioned in the 1st post are probably from the interlacing, I don't know if xvid4psp will autodetect & correct this
Without getting into avisynth, scripting & deinterlacing, the easiest way is probably to use Soopafresh's mini guide here with easy to use batch files
https://forum.videohelp.com/topic346331.html
The problem is you can get artifacts with interlaced AVC using DGAVCdec because it's based on an earlier libavcodec version that had problems with interlaced AVC material, I think Soopa might have made a batch script for DirectShowSource, you might have to dig around for it...
If you're familiar with avisynth I would use a recent build of ffdshow (h264 enabled in the configuration), haali media splitter, and avisynth 2.57 or greater
You can copy that to a notepad .txt file and rename the extension to .avs, changing the filenames and paths to match, and adjust the resize if you want to. Just feed that .avs script into any encoder that accepts avisynth as input, eg. xvid4psp, megui, ripbot.Code:Load_Stdcall_Plugin("C:\Program Files\AviSynth 2.5\plugins\yadif.dll") DirectShowSource("file.m2ts", fps=29.97, audio=true) Yadif(order=1) #Top field first LanczosResize(720,400) -
I dont know about sony vegas but here is a simple guide to using freeware to convert from m2ts to mkv...
http://crabsticks.co.cc/how%20to%20convert%20m2ts%20to%20mkv.html
hope this helps....
Sony Vegas Pro 11 crashes with Hauppauge HD DVR m2ts files! Help please!
By soccawalka5 in forum EditingReplies: 22Last Post: 18th Mar 2012, 02:53 -
Sony Vegas Pro 10 / .M2TS Error
By Ownaholic in forum Software PlayingReplies: 0Last Post: 5th Nov 2011, 05:21 -
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
How to convert MKV / MP4 to m2ts
By Bonie81 in forum Video ConversionReplies: 0Last Post: 9th Jun 2011, 14:47 -
Converted from m2ts into Sony AVC MP4 and got lines on objects
By dilfatx in forum Video ConversionReplies: 4Last Post: 1st Dec 2008, 12:00
