I isolated down to MPC HC as the only source that's causing the Ati2mtag and/or dxva_sig messages either in the folder where the video clips are or in the Event Viewer, they are NOT listed as "Warnings" or "Errors" just Event ID 62464 Ati2mtag DVD-OV...is this just information from my ATI card? or it's telling me MPC HC is using the hardware accelerated mode? other than appearing in the Event viewer, it's not doing anything harm or anything to my sys....should I be bother?
Thanks.
I'm pretty sure the errors are from the ATI drivers. I've had similar messages occasionally. My video card does use hardware acceleration. About all I can suggest if it's causing problems is to try different versions of the drivers. Someone here may have some better ideas.
Thanks redwudz. I guess I'll use ATI Catalyst Drivers 8.5 instead of the latest 8.11....actually for non gamer like myself, I don't really need the latest version of ATI Catalyst Drivers, what I need is a stable version of the ATI Catalyst Drivers that's plays/works perfectly with MPC HC 8) .
Best regards.
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 10:52 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 21:41 -
WMM crashes everytime I import audio and I'm PISSED AS HELL
By Nintendo Fan in forum EditingReplies: 3Last Post: 23rd Oct 2008, 15:46 -
Wot the fark is this? I get this popup everytime my cursor touches a video
By jaxxboss in forum ComputerReplies: 6Last Post: 22nd Jun 2008, 09:28 -
HELP! reactivating SATA drive everytime i boot?
By JayArea408 in forum ComputerReplies: 3Last Post: 2nd Sep 2007, 16:12
