You may have experience in selection of the pictures or video clips when importing them in the Edit Window. I wonder how to quickly select pictures. I do not want to select or import all pictures from the first to the last, Rather, I want to select or import pictures between some one to the last picture such as from the 20th to the last picture. If I select the pictures one by one by holding the Ctrl key starting such as from the 20th until the last picture, it will be time consuming. If I press Ctrl + A keys, all pictures from the first to the last will be selected. But, it is not what I want. Does anyone know how to quickly select pictures between the specific one and the last picture such as from the 20th to the last picture instead of clicking the pictures one by one by holding the Ctrl key?
you don't say what application you are talking about, so I can only give generic windows shortcuts..you can always select an image/file/whatever, then go further down the list and hold SHIFT + CLICK on the last file or another file and it will select all between the first file you clicked on and the second file you clicked on while holding SHIFT.
Thanks. The SHIFT + CLICK is exactly what I want. Can anyone list or locat all windows shortcuts, by the way?Originally Posted by greymalkin
Through the magic of google : http://www.helpwithpcs.com/tipsandtricks/keyboard_shortcuts_windows_xp.htm
Read my blog here.
There is no Shift + Click to select in that magic google search, isn’t it?Originally Posted by guns1inger
Need help quickly converting (stretching, really) a 4:3 mpeg into 16:9
By rhaynes999 in forum Video ConversionReplies: 14Last Post: 26th Feb 2010, 20:20 -
How can i quickly edit a wmv?
By Stemondo in forum EditingReplies: 2Last Post: 15th Apr 2009, 20:41 -
Quickly ripping clips for use with PE7?
By buddycat in forum Video ConversionReplies: 2Last Post: 17th Mar 2009, 06:32 -
How to quickly find which films contain subtitles
By Arlo in forum DVD RippingReplies: 2Last Post: 6th Jan 2009, 19:29 -
How do I take downloaded AVIs and encode quickly?
By randyannie in forum Video ConversionReplies: 1Last Post: 6th Oct 2007, 04:29
