Ok so i have Direct tv and i plugged in an ethernet cable into it and into my computer and this is what popped up
http://img370.imageshack.us/img370/1994/63075662gi7.jpg
Is there anyway to like extract recorded programs or view live tv?
Check to see if it has a firewire connection. High def dvr's usually do. If it does than you can do realtime transfers using capdvhs. However many channels will be encrypted and uneditable, even nonpremium channels.
You can also look into capture devices that can accept component cable inputs if this is a high def receiver.
The only other option is to use either svideo or composite cables and copy that way. Chances are the only reason the device has an ethernet connection is for internet updates for the program guides instead of using a phone line. Or some other "future" service that hasn't been implemented yet. But I think you will find there are practically 0 dvr or cable/sat boxes that would allow a file transfer over an ethernet cable. And even if you could the files would still be encrypted and need to be stripped.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Help capturing from cable box with Windows 7
By SpydaMan in forum Capturing and VCRReplies: 20Last Post: 4th Jan 2012, 09:42 -
Capturing VHS/Cable - What to buy?
By rbxbots in forum Capturing and VCRReplies: 14Last Post: 15th Aug 2010, 18:56 -
Hi Def capturing from cable box to PC
By vetski179 in forum Media Center PC / MediaCentersReplies: 4Last Post: 24th Nov 2009, 15:07 -
Capturing Cable DVR Help
By Chala in forum Capturing and VCRReplies: 4Last Post: 6th Oct 2008, 17:53 -
Capturing HDTV with ethernet cable
By superdud1400 in forum Capturing and VCRReplies: 1Last Post: 17th Jun 2008, 23:31
