Hi all,
I just bought a pc on Ebay. It's the Dell GX520 model, which will finally replace my old pc that can barely run Win XP.
I thought I might as well go for it all and get a dvd burner too. The pc doesn't come with dvd compatibility so I have to buy and install one. The problem is, I am having trouble finding any sites that tells me which models of burners are compatible with the Dell GX520.
Does anyone know of any sites that'll list compatibility? Or does anyone know of any dvdburner models that is definitely compatible with the dell model that I purchased?
Thank you!
				Results 1 to 15 of 15
	You can buy any DVD Burner and install it in any brand computer. You just need to know what interface burner to buy - either PATA or SATA. Check the Dell web site for that model and see what the specs are.
 EDIT:
 Thanks wtsinnc - I stand corrected - you can use either SATA or PATA drives .
						"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner .
 (NO MAN IS JUST A NUMBER)
 be seeing you ( RIP Patrick McGoohan )
	THREADKILLER !
 References on File.
	It doesn't say much in the manual of what type of dvd burner is in there. Here's a link showing a picture of inside of the computer case. It sure looks like it's a PATA dvd burner/dvd-rom.
 http://www.dell.com/content/products/productdetails.aspx/optix_gx520?c=us&cs=22&l=en&s=dfh
	From the link that wtsinnc provided:
 Controllers
 Drives
 four serial ATA controllers supporting one device each and one parallel Ultra ATA/100 IDE supporting two devices per channel with one channel
 Mini Tower = 4 SATA, 1 PATA
 Desktop = 2 SATA, 1 PATA
 Small Form Factor = 1 SATA, 1 PATA"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
	 Does it actually tell you what type of dvd burner is installed on it?  I don't see any of that in the manual.  Read closely because even it shows SATA controllers it doesn't mean anything since there is one Ultra ATA/100 IDE channel.  Look at that pic in the link I posted.  That drive sure looks like it has a IDE RIBBON CABLE & MOLEX POWER.  If it was SATA that would not show a IDE CABLE & MOLEX POWER connection. Does it actually tell you what type of dvd burner is installed on it?  I don't see any of that in the manual.  Read closely because even it shows SATA controllers it doesn't mean anything since there is one Ultra ATA/100 IDE channel.  Look at that pic in the link I posted.  That drive sure looks like it has a IDE RIBBON CABLE & MOLEX POWER.  If it was SATA that would not show a IDE CABLE & MOLEX POWER connection.
 The best way is to for the OP to open up that DELL pc he got off ebay and look at the DVD drive.
 Just my 2 cents!
	Alternatively you could go with an external USB box with a DVD burner inside. "Art is making something out of nothing and selling it." - Frank Zappa
	budz: My posting is from the Computer Specs page in the manuals that are provided in wtsinnc's link. The Hard Drive will be on 1 SATA channel in any of the 3 form factors - therefore, the Small Form Factor unit will only be able to use a PATA Burner. The other form factors will have both SATA and PATA channels available to use for Optical Drives.
 The picture in your link does indeed show a PATA Ribbon Cable, but that does not change the fact that you can use either format - the Drive that was originally installed by Dell was most likely a PATA Drive.
 Now - as to preferences of which interface to use, I will leave that up to the original poster to make that decision based on the recommendation of others
 Quote from the OP "The pc doesn't come with dvd compatibility so I have to buy and install one".
 If it has a CD Drive, then he can either replace it , or add the DVD Burner if there is room in the case."I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
	Thanks everyone. I am still waiting for the computer to arrive. I'll open it up and see once it arrives.
 The computer is only 17 inches tall according to the specs, so I think I'm gonna have to replace the cd drive. Probably no room for both.
 Please excuse my ignorance. Does PATA and SATA refer to the way the burner connects to the computer?
	Yes. If it already has a CD Drive, then it is most likely PATA with a wide 40 pin ribbon cable. The easiest solution would be to get a PATA DVD Burner and just swap out the Drives.Originally Posted by LWC"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
	Originally Posted by Number Six I can read..... I know the computer can use either PATA or SATA.  I merely posted that link so it could show what I found....BTW just because a mobo has SATA controllers it doesn't necessarily mean a SATA DVD burner (OPTICAL DRIVE) will work correctly.  It would depend on the SATA chipset controller of the mobo.  INTEL ICH 7/8/9/10 will work with SATA Dvd burners and NVIDIA when using the latest NVIDIA chipset drivers.   But the VIA chipset will not work with SATA DVD burners so one would have to use a SATA PCI CONTROLLER card with the SILICON IMAGE 3112/3114/3512 chipset.  Also older motherboards that have SATA controllers were made only for hard drives and not optical drives.  Just my 2 cents! I can read..... I know the computer can use either PATA or SATA.  I merely posted that link so it could show what I found....BTW just because a mobo has SATA controllers it doesn't necessarily mean a SATA DVD burner (OPTICAL DRIVE) will work correctly.  It would depend on the SATA chipset controller of the mobo.  INTEL ICH 7/8/9/10 will work with SATA Dvd burners and NVIDIA when using the latest NVIDIA chipset drivers.   But the VIA chipset will not work with SATA DVD burners so one would have to use a SATA PCI CONTROLLER card with the SILICON IMAGE 3112/3114/3512 chipset.  Also older motherboards that have SATA controllers were made only for hard drives and not optical drives.  Just my 2 cents!
 To LWC: If your computer is compatible with using a SATA DVD Burner then my suggestion would be to get the PIONEER 216D drive. If it's not then you can get a SATA PCI CONTROLLER card or just buy a PATA DVD burner like the PIONEER 116D or the PIONEER 115 drive. PIONEER's website is still selling the PIONEER 115 but the drive is silver in color. It's $34.99 with 1 cent shipping. I've many of them for myself and for some builds that I've done recently.
 PIONEER 115, SILVER, $34.99 with 1 cent shipping
 http://www.pioneerelectronics.com/PUSA/Products/HomeEntertainment/Blu-rayDisc+DVD/Blu-...5D+Silver.Kuro
 SATA PIONEER 216, $30.99
 http://www.newegg.com/Product/Product.aspx?Item=N82E16827129032
 SATA LG GH20NS15, $22.99
 http://www.newegg.com/Product/Product.aspx?Item=N82E16827136149
	Thanks budz - very good info about SATA  .    I do not have any experience with SATA - I only have 1 motherboard that has SATA connections, but I do not use them - that is why I am staying neutral on the choice .    I do not have any experience with SATA - I only have 1 motherboard that has SATA connections, but I do not use them - that is why I am staying neutral on the choice . .
 I also did not mean any offense - I originally thought that the unit will only accept an SATA drive, but the documentation listed both interfaces. Bjs also thought the same. I did see the ribbon cable in your post, as well as in the documentation under the Drives section of the manual.
 LWC wanted to know what will be compatible with the computer that he bought - so I was trying to give all the relevant information.
 EDIT:
 I just noticed something in the documentation - the Small Form Factor model uses a LAPTOP OPTICAL DRIVE ! !
 If that is the model computer that you bought, then it is a whole different ball game."I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
	Budz, thanks for your suggestion. Once I receive the computer and confirm that it's pata, I'll get the pioneer 116d model.
 In your experience, which brand of DVD-r works best with the Pioneer burners? I see some nice deals for Maxell and Memorex brands on ebay, which has a 10% discount until Sunday.
  blue ray software compatibility with standard dvd burnerBy Geules11 in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2011, 18:27
  Dell with a NEC 2100AD DVD+R writer - flash update to write to DVD-R?By DirtBikeMike in forum ComputerReplies: 5Last Post: 30th Sep 2010, 12:24
  DVD Burner for a Dell laptopBy PhoneMatt in forum ComputerReplies: 5Last Post: 26th Oct 2007, 13:15
  Reccommend a good burner for max compatibility?By Bansaw in forum Authoring (DVD)Replies: 11Last Post: 25th Jul 2007, 21:19
  DVD Burning on Dell Latitude D520By chrang in forum Newbie / General discussionsReplies: 7Last Post: 20th Jul 2007, 13:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
