    Nov 2008
    Bulgaria
    Hi,
    I have laptop Toshiba with GMA 950, and want to connect LCD TV (LG 32LC52) via S-video cable.
    TV has both S-Video and Composite plugs.
    In this topic https://www.videohelp.com/forum/archive/notebook-s-video-output-and-rca-tv-t340968.html
    people told that GMA 950 not support Composite out even with S-video <--> Composite cable,
    but I use this TV with S-video <--> Composite cable and it works.
    The problem is wen I use S-Video <--> S-Video cable, laptop identify TV connected(in use), but there is no picture on TV
    Was checking in all menus in laptop and TV( changing NTFS/PAL and all other setnigst i can) and can't understand why there is not picture with S-Video <--> S-Video cable but there is picture wen use
    S-Video <--> Composite cable.
    please help
  2. There are often limitation on the desktop resolution if you want to use s-video or composite out. Try setting the desktop resolution to 1024x768 or less and see if that helps.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Also determine whether or not the port on the laptop is a 7 pin connector or a 4 pin connector. The 4 pin connector is common on dvd players and the like. The 7 pin is more common for computer outputs. You should be able to get a 7 pin at your local electronic store should you need one.
    Nov 2008
    Bulgaria
    There is two available resolutions for TV-out 1024x768 and 800x600 both don't work, S-Video port on the laptop and TV are 4 pin
    I think there is two reason for the problem, the laptop send a analog signal that TV cant recognize or TV S-Video don't work.
    Whatever, I will tray S-Video signal form different source ... to see were is the problem in laptop or in TV
  5. If you used an s-video to composite adapter and got a picture from that the s-video port on the laptop is working. Try using that cable/adapter again. Once you get a picture on the TV (don't turn the computer off or reboot, leave Windows running) swap the cable/adapter with the s-video cable. Still working?
    Nov 2008
    Bulgaria
    I already do this, don't work.
    The cable or the TV, that left.
    Thank you!
