Hi guys (and especially the makers of MPC HC, keep up the good work! :thanks, I m using the MPC HC edition for some time now and have to say that I am very pleased with it. Especially because of the Anti-tearing option! It resolved all of my issues I had before.
Still I have some questions about some general options that can be selected in the MPC HC edition. So I hope you guys here can clarify them so I know what they do/what they are for.
In the Options menu of MPC there are the following things I would like to know what they are for. In the Output menu:
- Surface: regular, 2D and 3D. Best to pick?
- Resizer: Nearest Neighbor, Bilinear, Bilinear (PS 2.0), Bicubic A=-0.60 (PS 2.0), Bicubic A=-0.75 (PS 2.0), Bicubic A=-1.00 (PS 2.0)
- YUV mixing: check or uncheck?+what is it for?
- Lock back-buffer: check or uncheck?+what is it for?
Then there is the Audio Switcher
- Enable build-in audio switcher: check or uncheck?+what is it for?
Thanks for all help and sorry for my bad English.
Closed Thread
Please don't cross post. https://forum.videohelp.com/topic359985.html
MPC-HC settings?
By Hoser Rob in forum Software PlayingReplies: 4Last Post: 22nd Jan 2012, 10:51 -
General Computer Questions
By mccoady in forum ComputerReplies: 9Last Post: 28th May 2011, 23:44 -
Compression Settings General
By oc6088 in forum Video ConversionReplies: 13Last Post: 7th Oct 2009, 22:14 -
some MPC questions
By schmitt in forum Software PlayingReplies: 4Last Post: 5th Dec 2008, 19:04 -
MPC HC, some general setting questions
By THX-UltraII in forum Software PlayingReplies: 7Last Post: 25th Nov 2008, 10:13
