I hope i'm in the right forum for this, I've made several lil music videos and they are saved as avi files w/ divx codec used. When i convert it to a mpeg2 to be burnt onto a dvd-r for playback on a dvdplayer, i see these horizontal lines appear during fast paced sequences or if i added special effects into the music video itself. how can i fix this? is there a way to convert it so that those lines dont show up anymore? and if anyone can explain why they do show up, i'd appreciate it.
From what you described, i think you should try a different scaler/resizer. Biliniar should be for shrinking and Bicubic for enlarging.
You may be seeing interlacing artifacts as a result of the MPEG conversion. They will show up on a computer as horizontal lines on the edges of faster moving vertical objects, as a computer monitor uses a progressive display. If you use a interlace capable software player like VLC and select a 'deinterlace' mode, do they disappear?
Interlaced video is normal for MPEGs shown on a TV and they shouldn't show there either. Try playing back on of your DVDs on a set top player to a TV.
If it's not interlace artifacts, then you have a problem somewhere in the encoding process.
well yea, i mentioned i'm playing them on my dvd player...not a dvdrom.
any thoughts? i'll try that deinterlace thing if i even have that. i use tempgenc 3.0 express to convert files to mpeg2 ready files.
Ripbot264 Conversion Issue
By jmdale1984 in forum Video ConversionReplies: 3Last Post: 21st Feb 2012, 17:29 -
Audio/Video Sync Issue with .mts File Conversion
By arturo_morosoff in forum Video ConversionReplies: 2Last Post: 4th May 2010, 10:52 -
Quality conversion issue
By rcjhood in forum Video ConversionReplies: 5Last Post: 10th Mar 2010, 16:33 -
Conversion Issue
By yousif5877 in forum Video ConversionReplies: 4Last Post: 13th Feb 2008, 05:16 -
A unique conversion issue...
By DigitalArtist in forum RestorationReplies: 5Last Post: 21st Oct 2007, 20:26
