hey all i need some help, i've tryed to rip a DVD movie using dvd2svcd and it was successfully the quality is amazing when theres outdoor scenes but when the scene is dar i can see like a double widescreen, the black bar and top bar turn into a lighter black and it doesn't look good why is that can some 1 help me![]()
i'm guessing the movie is 2.35:1 widescreen? either dvd2svcd got the colorspace wrong or the original letterboxing is poorly done. if you want to fix it you need to edit the avisynth script to crop & replace the original letterboxing, but in any case you probably wont notice it on your tv
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
